Setup & License forum
keynotes and details
I am new to Archicad and am doing fine until I try to do construction documents. I have all the books, but information about doing details or keying in text seems to be lacking. What I want to know is:
1.) I use keynotes in my CD's, is there a standard, easy way to do this, or do I have to draw a little circle and insert a number, then copy and paste it to the area in the drawing I want to key?
2.) I'm trying to follow the Step-by-Step Tutorial book on page 139 (archicad version . In step 4 it is telling me to select the detail marker symbol from the popup menu. It gives a picture of this. When I try to do this, the Detail-Marker option is not listed. Do I need to load this somehow? How do I do that?
I'd appreciate any help.
Lori
__archiben
lori
in this case, you need to make sure that you have loaded all of the default libraries. the detail markers are library parts that need to be loaded into archicad to enable it's function.
you should be able to key in your text/marker reference in the 'parameters' list of the detail marker when you have it loaded and selected...
~/archiben
b e n f r o s t
You might also look at AutoKeyNotes by Undecillion at the Objectsonline website.
Richard
AC25 (since AC6.0), Win10
