Installation & update
no USB port for code meter key
peter spellman
Anyone dealt with how to plug in the code meter key when there is no USB port?
Recently purchased a new MacBook pro laptop with the following ports:
Three Thunderbolt 4 ports, HDMI port, SDXC card slot, MagSafe 3 port.
Is the an adapter that the code meter can plug into that would work around?
Thanks in advance for any suggestions.
Peter
Mjules
Mentor
You can buy a C Hub through Amazon. Click here to have an idea and look for what you need exactly.
Martin Luther Jules
AC 10-27 (Full)
Asus | 64 GB RAM | Windows 11
8 REPLIES 8
Mjules
Mentor
Martin Luther Jules
AC 10-27 (Full)
Thanks Martin.
You're welcome, Peter, and I wish you found a solution with that!
Martin Luther Jules
AC 10-27 (Full)
We use the software licenses on all of our MacBooks.
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.0
macOS Sonoma (14.4.1)
Jesse Davidson
I either use my wired apple keyboard (has 2 usb ports on the side of it) or use the USB C hub that has multiple outlets.  You can also purchase small USB C to USB A adapters on amazon.  They've all worked good for me.
ArchiCAD 24 Full
15" Macbook Pro (2018), OSX 10.15.7
2.6 GHz Intel Core I7, 32GB DDR4
Radeon Pro 560X 4096 MB[/size]
David Shorter
just purchase a USB4 to USB2 cable
Archicad 4.1 to 27 Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
If you were going to specifically look for a USB4 male, you would want more than a USB2 female on the other end. You would want a dock with a DP out at minimum else you would be wasting your money...
Sorry keep forgetting. I have a Mac studio which has 6 various USB-c ports of various flavors + 2 USB -a ports. This is luxury after my old MacBook Pro of 2013!!!!. So with my key and Bluetooth mouse in the 2 USB-a ports I still have 4 thunderbolt and 2USB-c ports free. Couple of cables is cheaper than a hub..
Mac Studio
iPad Pro
iPhone
