I often find it slow (the copy part) when I have version 12 open together with newer versions.
I still script in version 12 (lowest common denominator) while running newer versions at the same time and copying text in the scripts often pauses for a couple of seconds.
Having just 12 running on its own there seems to be no problem.
So it could well be a combination of programs (Archicad or not) that you have running at the same time causing the issue.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
