2019-06-10 01:07 PM
2019-06-11 04:54 AM
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Self-taught, bend it till it breaks | Creating a Thread |
Win10 | R5 2600 | 16GB | GTX1660 |
2019-06-11 05:46 AM
Lingwisyer wrote:By this Ling means your display scaling.
Do you have scaling active in Windows/OSx?
2019-06-18 10:10 AM
2019-06-18 10:26 AM
Piotr wrote:You may have to restart your machine to see any change to the dialogue.
I do have 150% (I work in 3840x2160). Changing the scale settings seems to have no influence in this case.
2019-06-18 11:58 AM
2019-06-19 03:32 AM
Piotr wrote:It may only look good until the next time you restart your machine.
I've changed the settings again to 150% and it also works well.
2019-06-19 04:12 AM
2022-06-27 01:55 PM
Hello, I have the same issue and tried the things you wrote, but nothing happend. Could you give me some other solutions for AC 25
2022-06-27 08:54 PM
So, you:
1. Switched Scaling to 100%.
2. Restarted Windows.
3. Restarted Archicad.
and the Dialog still gets cropped?
One thing about scaling and resolution: when I bought my 4K monitors, I was thinking between 3840x2160 resolution with 150% scaling and 2560x1440 resolution with 100% scaling. Both achieve the same visual result, or if there was a difference I could not tell. I decided to use the latter so I would not have to use Scaling.
