2022-04-26 03:01 PM - last edited on 2023-05-11 09:43 AM by Noemi Balogh
I have a problem regarding moving our license server to a Windows server 2019.
When i try to login at License Manager Tool, the "Sign in" button wont work.
Any thoughts what i could be, all other buttons are working.
I have tried to reinstall the software.
I have added the site to our "Trusted sites" in IE
Best regards
Tomas Eklöf
2022-04-27 03:15 AM
Can you try in different web browsers?
I use Firefox and it works there.
2022-04-27 06:51 AM
There are some issues with the sign in button with regards to display settings (scale and layout) specially if you are trying to login directly within Archicad. Hope this info helps you out. 😎
2022-04-27 07:48 AM
Hi Ryejuan,
Could I have misunderstood where you can have the License Manager itself?
Because I have always thought that it needs to be on the server itself against which the license is issued.
I have no problem log-in to GraphisoftID > Login on the server in IE, just only when using the Tool itself
2022-04-27 07:56 AM
Hi Barry,
Can you change the GSLM "tool" to start witch browser i want?
Or can you issue the license from witch computer you want?
I have this license as "software keys" from our server 2012
I have always thought that you need to issue the license from the server where you have installed the Tool and the codemeter.
I can login to the site from just IE, but not from the tool itself
best regards
Tomas
2022-04-27 08:19 AM
I assume the License Manager Tool uses whatever the default browser is.
Looking at your original image, the orange sign-in button will not be active until you enter your user name and password.
The button should then become a darker orange colour to say it is active.
I assume you are dealing with software licenses.
As far as I understand (I don't use them) is they can be accessed from any machine.
They are allocated to you company license pool, and then you access it (download it) on the machine you want to work from.
When you are finished with it, remember to send it back to the pool.
It may be wise to contact your local support people to talk you through it.
2022-04-27 09:14 AM
sorry for the confusion, usually Archicad itself will have that login screen in the beginning if you haven't signed in your GS ID then display scaling becomes an issue.
Then if you have problem accessing or pressing the sign in button try changing browsers usually it solves the issue. If still not working maybe got firewall issues, need to look into that too.
@Barry Kelly the orange button is active on my end even if I didn't key in any username and password.
2022-04-27 12:18 PM
No worries, my thoughts is that this is a firewall issue aswell.
I have sent this to our IT department, i will see what they will find out regarding this.
/Tomas
2022-04-27 12:32 PM
Hi Barry,
I have tried to change the default browser o the server, but it always start with IE.
I will send a case to Graphisoft and see if they have seen this problem before.
Best Regards
Tomas
