Installation & update
where to get 2d symbols for archicad?
ICEdevil
Do you know a website where i can find 2d symbols, other than the ones already bundled into the archicad library? (vehicle symbols, north-arrows, etc.) ?
i am interested in an exact link... i know i can search google...but this will save me a lot of time
thank you
ArchiCAD 11 build 1210
ArchiCAD 12 Hotfix 3
AMD Athlon 64X2 3800+, 2 GB DDR, Nvidia geforce 6600GT, Win XP SP2
4 REPLIES 4
Erika Epstein
objectsonline.com
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Djordje
Ace
You have to invest time at least.
Check Depository.
Check the Tips&Tricks forum, a lot of links are there.
Enjoy
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Also - your quality mileage may vary with this tip - if you have symbols in existing AutCAD dwg files - or create a dwg containing only the 2D Autocad symbols you are interested in...and those symbols exist as autocad 'blocks' - then you can convert them to GDL library objects in one step via the command:
File > Libraries and Objects > Import Blocks from DXF/DWG
You will be asked to browse to a folder and/or make one. All of the converted objects will be created in the indicated location.
One of the forum moderators
Many thanks for links. I have found there many useful things and information. Do you know something else? Once again thanks
