Teamwork & BIMcloud
Archicad 25 update from 5010 to 6000 in same teamwork BIMcloud?
ananas
Hello everyone!
We are using Archicad 25 (update 5010) and would like to upgrade to Archicad update 6000 or 7000 (due to Teamwork problems in update 5010 version). We are working with Teamwork which is installed on our local server.
I know we need to set up a new server (update BIMcloud) when we update to Archicad 26, but do we need to do this when we update all Archicad within version 25?
NWA
No, as long as all members of the team update to the same version of ArchiCAD 25 you are good to go. As soon as you open the project on an updated version you can no longer access it from an earlier built so that is something to look out for!
ArchiCAD 26.5002
Windows 10 Professional
NWA
ArchiCAD 26.5002
Hi!
thank you for explanation! 🙂
