2011-08-29 10:40 AM
2011-08-29 10:00 PM
2011-08-30 01:15 AM
2011-08-30 03:48 AM
2011-08-30 08:45 PM
Matthew wrote:That is not correct.
The local IP (Linksys typ: 192.168.1.***) is of no help accessing the server from outside your LAN. The issue is whether your ISP gives you a static IP or not. If so you can use that, if not there is software that can create a static IP for you. I use Hamachi on my Mac.
2011-08-31 12:18 AM
Karl wrote:Oops. Networking is not my strong suit. I thought the external static IP was necessary. That's how I've done it at least. Good to know there are alternatives.Matthew wrote:That is not correct.
A static external IP address is not at all required. In his original post, Alper noted that he is using a dyndns.com domain name which is no problem at all for dynamically re-pointing a static name to a dynamic IP address.
The static local IP is essential. Danj is pointing him in the proper direction in making sure that his local machine hosting BS has a static local IP address so that any port-forwarding that he sets up will always forward to the BS machine with no chance that the machine shifts to another local IP address.
Alper, the set-up can be quite cumbersome depending on your equipment. Having your router port-forward properly as described in the Wiki articles is necessary. But, depending on how your router gets your internet connection, more work may be needed. If you have a DSL modem, e.g., you must make sure that it allows those port requires through to the router (etc).
2011-09-15 09:52 PM
