2019-07-22 10:00 AM - edited 2023-05-15 01:46 PM
Most projects need time to be finished and within that time some version maintenance will be necessary. In general, a project with a 3-year life cycle or longer will need to be migrated to a fresher version of Archicad at least once. Project migration may even be necessary with a relatively short life cycle project started late in an Archicad’s version support cycle or requiring features in a fresher version of Archicad.
With each project migration make note that legacy libraries hurt the performance of a project, not just at every open, but also during several other operations. Therefore, you should let Archicad migrate the default libraries automatically upon first opening an older project. Additionally, if you have custom libraries or 3rd party libraries in the project you need to take separate actions.
The actions you should take to migrate your custom and 3rd party libraries are dependent upon each library’s content.
If your custom library contains elements from IFC, then the easiest way to migrate it is to create a library container file in the current Archicad version (.lcf).
Another typical use case is when you create a library with certain textures, or with objects modeled in Archicad, or with GDL programming. These are either stored as .lcf files, or in a real folder structure.
To be able to migrate these objects, you need to re-save all .gsm objects in the current version of Archicad one by one.
In the case you chose to store your Custom Library in a Library Container File (.lcf), you first need to extract its content to be able to re-save it in your current Archicad version.
When you finished with re-saving all .gsm files in your current Archicad version, you can either re-create your .lcf, or you can immediately re-upload your folder to the BIMcloud. After everything is uploaded, you can delete your previous libraries from the project.
Some manufacturers represent their product line with custom libraries (e.g. Velux opening). There are also some specific object libraries on the Internet (e.g. hospital equipment), which were created by a 3rd party company. These objects are usually password protected, unlike your own custom library, therefore it is not possible to follow the same steps mentioned for custom libraries.
In case you use such a library, you might need to contact the developer to have them update their library to the latest version of Archicad. If this is not possible, you can decide whether you wish to continue using this content in your project.
Am I understanding this correctly. I have a Custom Library with individual GSM objects I must resave each object in the newer version of Archicad.
I can't just convert a Folder of custom GSM objects into a LCF file and load that?
An LCF is just a file that contains all of the GDL objects - a bit like a ZIP file.
You need to extract that container to access the individual files and then amend (re-save) each one.
Then if you want you can re-create the container file.
That'll be quite a job to update 240mbs worth of Library objects as well as updating our Office Template file and Work Environment.
There is a reason why we still are using AC23 and yet have AC25 and it's various updates not being used on any active Projects.
I too have custom libraries (probably around 1GB all up).
They contain objects written in versions as old as 6.5
Of course some have been updated as needed, either because of new GDL commands or just to improve them in general.
But they get amended and saved in the oldest Archicad version we are using (currently 20).
I have noticed jobs take longer to load in 25 and it seems to pause at the part where it is loading libraries.
But once loaded it does not seem to affect the speed while working on the file.
So for now it is something I can live with.
Apart from the slower loading of files (but that could be because my 25 library is twice the size of my 20 library), I have noticed no ill effects of not updating all the library parts.
