Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Teamwork & BIMcloud
Projects BIMCloud Saas from AC27
George-vK
Hi all,
Yesterday we've installed the new Archicad 27 and are using BIMCloud Saas with Archicad 26. However, when trying to opening a project in Teamwork, the project folders are empty. Projects are vissible in Archicad 26, but not in AC27. Strangely enough, when I share a new project in AC27 to Teamwork, the projects are visible.
Any ideas? I allways understood it shouldn't be necessary to first open in AC26, save as pln. Then open in AC27 and share to Teamwork for all projects.
Thanks.
1 REPLY 1
Noemi Balogh
Projects hosted on SaaS should be migrated the same way as they were migrated with on-premises BIMcloud versions. You have two options: either run a Teamwork migration (https://help.graphisoft.com/AC/27/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC27_Help%2F010_Migra...) or via saving a PLN in Archicad 26 and re-sharing it from Archicad 27.
Noémi Balogh
Community Expert, Admin
