Teamwork & BIMcloud
Update a TW file from 5030 to 5060
Brandon-W_DWa
In all my past experience, opening a Teamwork project of build older than that of your version of Archicad would force you to update the project if you wanted to save. For example, if my version of AC is 27/5060, and I open a 27/5030 Teamwork project, I would be notified of the discrepancy upon opening the file, and then it would update to my build when I send & receive changes.
However, that isn't the case anymore. How do I update my teamwork projects?
Versions 25, 27, or 28
macOS Sonoma 14.7.1 - 2021 MacBook Pro 16", M1 Max Chip, 64gb DDR5
Browser: Google Chrome
Eduardo Rolon
You will need to check the help files but teamwork changed and version numbers that have the same first digit will work with any of the incremental versions so it will update once you send and receive with the highest build number and it will maintain compatibility with users that have not updated yet.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
This might be an exception. This happened in the office and the first digit of the build didn't matter.
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
I'll check the Help page, but it definitely doesn't upgrade when someone with 5060 S&R's on the 5030 file.
