Teamwork & BIMcloud
What needs to be reserved?
Lingwisyer
Guru
Hi all,
I have recently started using the Teamwork function and keep running into the issue of spending too much time trying to figure out what needs to be reserved to do various things that I resort to reserving all...
One of these places is in details, where I get a message saying "You must first reserve this viewpoint". That is even after I have reserved the detail, the detail marker and the entire drawing that contains the detail marker... Why is there not simply a button on this message asking if I would like to reserve this viewpoint?
The other is with Transmittals. There is no reserve button, so... but I do not need everything reserved to edit it? I select Reserve All, then do not request any currently reserved items and it lets me edit it. What hidden item am I reserving?
Ling.
runxel
Hero
Ha, I thought I'm the only one! 😄
I also sometimes wonder what did I miss here?
Also a lot of dialogs do not have the button in bottom so only after you've done changing things you realize woopsie the "OK" button is greyed out...
Yeah, I feel like I need to get into the habit of checking if the "OK" button is active or not before I modify anything in a dialogue...
