BIM Server system components
Istvan Moharos
Related versions: v18 and newer
 In case of the following system components, both the network communication and file related operations need to be on the exclusion list if any antivirus/firewall/network monitoring application is used.
Components
BIM Server Manager
Services and Processes
Version Service / LaunchDaemon Processes
v21 Graphisoft BIMcloud Manager 21.0 (PortalServerService-v21.0) TeamworkPortalServerManager.exe Node.exe TicketProvider.exe
v20 Graphisoft BIMcloud Manager 20.0 (PortalServerService-v20.0)
v19 Graphisoft BIMcloud Manager 19.0 (PortalServerService-v19.0)
v18 Graphisoft BIMcloud Manager 18.0 (PortalServerService-v18.0)
Folders and files
Folder / File Operating System Path
Installation folder * Windows C:\Program Files\GRAPHISOFT\BIM Server <version>\BIMcloud Manager\
macOS System drive/Applications/GRAPHISOFT/BIM Server <version>/BIMcloud Manager/
Configuration folder Windows ...\BIMcloud Manager\Config\
macOS .../BIMcloud Manager/Config/
Manager's database folder ** Windows ...\BIMcloud Manager\Data\
macOS .../BIMcloud Manager/Data/
Logs folder Windows ...\BIMcloud Manager\Logs\
macOS .../BIMcloud Manager/Logs/
BIM Server Module
v21 Graphisoft BIMcloud Server 21.0 (TeamworkApplicationServerMonitor-v21.0) TeamworkApplicationServerMonitor.exe TeamworkApplicationServer.exe Mongod.exe
v20 Graphisoft BIMcloud Server 20.0 (TeamworkApplicationServerMonitor-v20.0)
v19 Graphisoft BIMcloud Server 19.0 (TeamworkApplicationServerMonitor-v19.0)
v18 Graphisoft BIMcloud Server 18.0 (TeamworkApplicationServerMonitor-v18.0)
Folders and files
Installation folder * Windows C:\Program Files\GRAPHISOFT\BIM Server <version>\BIMcloud Server <version>\
macOS System drive/Applications/GRAPHISOFT/BIM Server <version>/BIMcloud Server <version>/
Configuration folder Windows ...\BIMcloud Server <version>\Config\
macOS .../BIMcloud Server <version>/Config/
Projects folder ** Windows ...\BIMcloud Server <version>\Projects\
macOS .../BIMcloud Server <version>/Projects/
Attachments folder ** Windows ...\BIMcloud Server <version>\Attachments\
macOS .../BIMcloud Server <version>/Attachments/
BlobCache database folder ** Windows ...\BIMcloud Server <version>\BlobCache\
macOS .../BIMcloud Server <version>/BlobCache/
Session database folder Windows ...\BIMcloud Server <version>\Sessions\
macOS .../BIMcloud Server <version>/Sessions/
Messaging database folder Windows ...\BIMcloud Server <version>\Mailboxes\
macOS .../BIMcloud Server <version>/Mailboxes/
Logs folder Windows ...\BIMcloud Server <version>\Logs\
macOS .../BIMcloud Server <version>/Logs/
BIMcloud Monitor
v21 Graphisoft Service Process Manager Agent 21.0 (TeamworkServiceProcessManagerAgent-v21.0) TeamworkServiceProcessManagerAgent.exe BIMcloudMonitor.exe
v20 Graphisoft Service Process Manager Agent 20.0 (TeamworkServiceProcessManagerAgent-v20.0)
v19 Graphisoft Service Process Manager Agent 19.0 (TeamworkServiceProcessManagerAgent-v19.0)
Folders and files
From version 19 both BIM Server components contain the BIMcloud Monitor application.
BIMcloud Monitor Application Windows ...\BIMcloud Manager\BIMcloudMonitor.exe ...\BIMcloud Server <version>\BIMcloudMonitor.exe
macOS .../BIMcloud Manager/BIMcloudMonitor.app .../BIMcloud Server <version>/BIMcloudMonitor.app
 Notes: * The path can be modified during the installation phase. ** The path can be modified either at the configuration phase or later by reconfiguring the affected BIM Server component.
Communication
Communication between the client and the server side components
Source Destination Port Number Protocol
ARCHICAD 21 BIM Server Manager 21000 HTTP
BIM Server v21 Module 21001
ARCHICAD 20 BIM Server Manager 20000 HTTP
BIM Server v20 Module 20001
ARCHICAD 19 BIM Server Manager 19000 HTTP
BIM Server v19 Module 19001
ARCHICAD 18 BIM Server Manager 1228 HTTP
BIM Server v18 Module 18008
Communication between the server side components
Note that in case of BIM Server the server side components can only be installed on the same computer, so this communication is local.
BIM Server Manager BIM Server v21 Module 21001 HTTP
 Note that the above ports are defaults, if the ports are customized, then the appropriate customized ports have to be used.
Browse more articles
Back to articles
