Visualization
3d Antialiasing in Archicad 27
David Collins
I’m seeing a big difference in the 3d window from AC26 to AC27. In particular, there doesn’t seem to be any antialiasing in AC 27. ā€œ3d anti-aliasing (with Hardware accelerated mode)ā€ is checked in both cases. All other settings are also identical.
Is anyone else seeing this?
Maybe there’s some issue with the NVIDIA GeForce RTX 3070 in AC 27?
ā€ƒ
ā€ƒ
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
David Collins
A restart fixed this. I'm not sure what was going on.
David Collins
Seems someone else has noticed a similar problem.
https://community.graphisoft.com/t5/Visualization/3D-Graphics-got-worse-24-gt-27/m-p/576062#M24629
The 3D window needs to be closed and opened for the change to the 3D setting to have effect - perhaps this wasn't done before and the restart did it?
