2008-10-02
01:57 PM
2023-05-11
12:20 PM
Noemi Balogh
2008-10-02 05:57 PM
2008-10-02 06:19 PM
Dwight wrote:Oh Guru Dwight
Or, yes, an array of leaf parts on a slab Let the top be flat but jiggy up the sides a little.
2008-10-02 06:31 PM
2008-10-02 07:07 PM
Dwight wrote:OK. The hedge looks good, but it's got all those polygons - I hope the texture on flat surface would render faster.
The hedge shown is the Archicad hedge.
If you want to put leaf parts on a slab, just get some pictures of leaves, assemble them in Photoshop, use a mask to have some transparency.
This will transfer to Artlantis.
2008-10-02 07:14 PM
2008-10-02 08:03 PM
2008-10-02 08:37 PM
2008-10-02 09:30 PM
Dwight wrote:Well that's pretty much exactly what I'm aiming at with my hedge...
That image is an invisible cylinder with a masked bitmap of leaves.
This is easy in Archicad or Artlantis, but Photoshop is where the image and masking happens.
Make some vines climb in a blank image, and mask out the background. This means a large map with a large coverage, say, the height of the column.
2008-10-02 09:34 PM
