heathldesign
Custom surface image mirrored?
I have imported some pics that i intend to use as background images in 3D, as a surface so i could more easily place the image at scale and in the correct relative position, because placing a background image in render settings is quite stupid really. anyway, my images in my embedded are correct, but when the surface is applied to my wall, it's mirrored. is there some setting i'm missing? having a mirrored surface is fine in most cases, but not when it's a scenery image.
Operating system used: Mac Apple Silicon Sequoia
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.3. AC 27, 6000 USA
1 Solution
Does inverting the direction of the wall change anything?
Go to post
heathldesign
Barry, what would we do without you? you should be on payroll with GS.
