Ahmed_K
Mentor
FBX export issue
The previous datasmith fbx exporter create clean geometry, the actual FBX exporter triangulates all faces,
Any solution to have clean geometry , it's impossible to work with such model in 3ds max.
Archicad 27
Windows 11 professional
4 Replies 4
Lingwisyer
Guru
Is this with the native FBX exporter, which I think was added in AC28, or a 3rd party one such as the one previously supplied by Epic for TM? Also, what do you mean by "datasmith fbx"? They are two different formats...
Ahmed_K
Mentor
the screenshot shows the result of the native FBX format from Archicad 27.
since Archicad 24 , the old FBX ecporter provided by epicgames is not available, that exported creates clean geometry ,
the fbx exporter for Archicad 27 create triangulated geometry.
Archicad 27
Lingwisyer
Guru
Is the geometry of an imported FBX editable? Could you try apply a quadrangulate modifier to your imported model?
Ahmed_K
Mentor
yes , it's an editable mesh , quandrangulate modifier did not remove triangulation.
Archicad 27
