Gleb1
Grass does not show up in the visualization
Hello. I have this problem: I use a special 3D grass cover, but on the visualization it looks flat and not volumetric.
How can I fix it?
3 Replies 3
Is the 'Grass' option turned on in the photorender settings?
Most of the pre-set scenes will probably have this turned off.
Lingwisyer
Guru
Do note that turning on grass will murder your render times...
Erwin Edel
You might want to only use the 3D grass up close to the camera.
Even a simple grass texture on a huge bit of terrain increases rendering times dramatically.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
