How to crop a picture according to the contours in Archicad 26?
Vilman20
I can't find which tool to cut with
Erwin Edel
Place the image with the drawing tool instead.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Erwin Edel
www.leloup.nl
Windows 10 Pro
ryejuan
Can you crop image in Archicad? What I usually do is create a fill with a solid background that would hide the other parts of the image I don't want to show.
In the end what is your Objective?
ArchiCAD 9 onwards
Tonka
Thank you, Erwin. You are really Rockstar!
I`d never thought to insert jpg with drawing tool. It works perfectly.
