alemanda
How to store permanently render settings as view
I'm discovering Cinerender more and more.
I recently discovered the batch-render-like feature using the publisher.
Great!
Now I have an issue.
I set the render views as "view" but every time I open the file I lose the settings, in particular the size of the rendering.
Why?
How to set it permanently.
Thanks for any help!
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
Erwin Edel
Sounds related to this other problem with presets not sticking.
http://archicad-talk.graphisoft.com/viewtopic.php?t=51571
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Not sure if this is exactly what you're asking, but...
Recently, I have been saving 3d views as in the View Set and then placing them in layouts. Once I'm happy with setout, I right-click the view set item and in the view settings dialogue box's 3D section, change the "Generate In" item from 3D Window to Photorendering, selecting a customised and pre-saved renjdering scene in the item below. I then use the publisher set to output to required image format. I haven't noted any issues regarding changing view sizes.
You could skip the layout bit, placing 3d view items directly into publisher set folder, however as I have been trying out exporting the same views in various render types (sketch, cinerender, 3d view etc.) and then importing and overlaying them in photoshop for post-processing, I find having them on a standard sheet size makes alignment/scaling in photoshop easier.
