3 hours ago - last edited 3 hours ago by Barry Kelly
My office computer had an update and when I try opening a file in Archicad, the file explorer that pops up doesn´t have the "quick acces" folder like it used to have before the update. I have to look on hundreds of folders to find the one I need. How on earth can I fix this?
Solved! Go to Solution.
3 hours ago
I found how to make it work. When I open the file explorer, I went to the top panel and clicked on the 3 dots, then Options. In the general tab, I selected that file explorer opens for "Start". Now when I open a file in Archicad, I have the "Start" option in the right panel, and there are all the pinned files.
That would be a Win11 question, not an AC question. Does Start not show you what you want? Looks about the same. I never use Quick Access so I never noticed the UI change.
Also, has nothing to do with Visualisation...
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Self-taught, bend it till it breaks | Creating a Thread |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
3 hours ago
I don't have it in Windows 11 either.
It may not be there in Windows 11 like it is in Windows 10.
If it is, then there will be a Windows System setting somewhere to turn it on, but where I do not know.
This is it in Windows 10, if anyone knows how to turn it on in Windows 11.
I suspect it is just not there now unless you can go into some 'classic' mode.
3 hours ago
