2017-03-13
05:20 PM
2023-05-11
11:57 AM
Noemi Balogh
Solved! Go to Solution.
2018-05-14 08:43 PM
2017-03-13 09:18 PM
2017-03-13 09:41 PM
2017-03-13 10:13 PM
2017-03-14 09:44 PM
ESP182 wrote:No, I meant the white model render option, as opposed to coloured / photorealistic render. Saving the view (3D window) keeps the settings but not the image. You still have to render the view to get the image. Hope this makes sense.
Thanks -
When you say "white model" and save as a view, I'm presuming you are saying b/w with hidden lines?
2018-05-14 04:53 PM
mikas wrote:Hello, I'm quite new to Archicad and I was surprised to see that the program doesn't save a render view directly like the camera. This is why I ended up here in this post.
You can save a view as a render-window, see "Save View" options source menu at the bottom of the dialog. If you check the white model-option from render settings, it will be saved too. You can change the settings for a rendered view later to white model setting if you need to. If the views are changed, they will auto-update then the layout is visited.
I personally do not think it's a very practical thing to save render views straight to layouts though. The renders almost allways needs a little bit of tuning, at least with brightness and/or contrast. Thats why I too use external links to renders.
But you never know what others need or want.
2018-05-14 08:43 PM
2018-05-15 11:00 AM
2018-05-15 11:14 AM
t_and wrote:Before you create your view , right mouse click in the 3D window and choose "2 point perspective".
It worked perfectly! thanks you very much for your help😉
Just to make it perfect 100%, is there a way to set the camera so that all the vertical lines always stay vertical (vertical perspective correction) ? Views always look nicer if the verticals don't have a fuge point when the camera and target aren't in the same height.
Thanks a lot and have a nice day.
2018-05-15 04:53 PM
