2018-08-2309:01 AM - last edited on 2023-05-1102:58 PM by Noemi Balogh
2018-08-2309:01 AM
Is it only me but I have the feeling that we have better scenes with Sky than with HDRI library images. I can obtain much better and crispy images using Sky than HDRI. Is it only my feeling?
Hmm, that's interesting. I've thought HDRIs are calibrated to have a big enough range between bright and dark so you wouldn't need to do this manually. Perhaps Cinerender has some special way of using HDRIs which differs from other renderers..
Okey, that's interesting I've never had to do this in Cycles, Vray etc. to achieve desirable results. I'll look into this
Another approach would be to remove the sun completely and use the ArchiCAD sun for direct light. I have some HDRIs setup this way I can try!
