Visualize articles
Articles
Renewed Additional Surface Catalog
The Additional Surface Catalog needed an update Our users’ essential wish was to update the Additional Surface Catalog. The previous catalog did not fully support the new rendering capabilities within Archicad with the default settings, which require...
Cast shadows in BIMx Mobile
More realistic visuals Realistic visuals are becoming increasingly important in architectural presentations. BIMx presents a visual quality enhancement for a more realistic look: the new Cast Shadows render mode! Explore the virtual building with thi...
indoor shadows.gif RolandSzabo_3-1657616231816.png favorites960p.gif RolandSzabo_2-1657616129475.png
Updating Rendered Views on Layouts Automatically
A quick way of keeping your rendered images up-to-date without re-rendering them manually after changing the model is to use the 3D Only panel of the View Settings. Instead of rendering the specific camera views, then saving and placing the final .jp...
screen-shot-2016-02-12-at-12-53-56.png screen-shot-2016-02-12-at-10-57-56.png
Quick Graphical Quality Checks with Archicad
With the improved Graphic Overrides now RGB colors can be selected for Background Fill Pens and 3D surfaces in Graphic Override rules. This way, you do not have to create separate pens and surfaces with a specific color to highlight elements if you w...
wp-content_uploads_2021_05_Screenshot-2021-05-03-at-13.31.01.png ac25-quick-graphical-checks.jpg
Powerful Design Presentations with Archicad
Surface Textures on Section/Elevation/Interior Elevation Views Limitations on graphic representation tools require time-consuming workarounds and the help of external software that breaks the BIM workflow. In previous Archicad versions, displaying hi...
wp-content_uploads_2021_06_Untitled-480p-210602-1.gif wp-content_uploads_2021_05_Archicad-25.png wp-content_uploads_2021_05_Screenshot-2021-05-04-at-14.03.38.png wp-content_uploads_2016_06_Info_18x18.png
Presenting multiple models in one BIMx Hyper-model
Have you ever thought about what would be the best way to present design alternatives to Clients? Or did you have a Renovation project where you struggled with presenting different stages of the reconstruction? Search no more because BIMx Hyper-model...
wp-content_uploads_images_entire-building.jpg wp-content_uploads_images_building-without-finishes.jpg wp-content_uploads_images_load-bearing-structures.jpg wp-content_uploads_images_design-variation-1.png
Perspective sections in Archicad
Sometimes the best tool to represent the building is a perspective section, allowing an insight into building spaces. We need to use a 3D cut, a 3D document and some simple Model Display settings to do get this right away. Step 1: Create Model In our...
wp-content_uploads_2012_09_sectional-perspective_ready-1-e1544605408945.png wp-content_uploads_2017_06_3point-1024x745.png wp-content_uploads_2012_09_marquee.png wp-content_uploads_2012_09_marquee-2-1024x605.png
Labels
