SOLVED!
No option to publish to DWG
brittsax
Hi in the publisher, the only option I have besides PDF to publish to is BIMx. I checked the Add Ons menu and DWG input/output is checked. Not sure if I am missing something - thanks
AC25 USA • iMac 27" 4.2GHz Intel Core i7 | 16 gb ram • OS Catalina 10.15.7
1 ACCEPTED SOLUTION
Solution
Have you created the publisher set necessary to publish DWG’s? You need to create a new publisher set and change the settings to DWG. There should be a button under the publisher settings in the navigator to change a new set.
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.0
macOS Sonoma (14.4.1)
2 REPLIES 2
Solution
Lee Hankins
Got it - I guess I had to create a new set. It wouldn't let me edit the existing set. Thanks !
Learn and get certified!
