General discussions
Posts about job ads, news about competitions, events, learning resources, research, etc.
Win an Apple iPod! AEC Building Design Practice Survey 2004
JCovarrubias
Graphisoft Alumni
Graphisoft Alumni
ends soon, survey takes about 8-10 minutes
http://vista-survey.com/survey/v1/survey.dsb?ID=1097094743
"For those that did not receive this from GeoPraxis there is a survey being done on BIM/3D tools sponsored by McGraw-Hill Construction, Autodesk, and Bentley. I think it is very important that ArchiCAD be well represented in the survey results so if you have e-mail newsletters, please consider forwarding this info to your ArchiCAD clients. And they can win an iPod mini...
Please notify your CAD users of this important industry survey to ensure they are represented.
GeoPraxis and Pacific Gas & Electric, in conjunction with McGraw-Hill Construction, Autodesk, and Bentley Systems, are conducting a detailed study of CAD usage in Architectural, Engineering and Construction building design practice. Complete the web survey and qualify to win one of ten Apple® iPod minis.
The study updates results of market research conducted by GeoPraxis in 1999 and 2000, and has been expanded to address the movement to BIM and 3D-CAD tools, interoperability between systems, as well as Green Building design and LEED qualification. Results will be published in late Summer 2004. A drawing of all qualified completed survey respondents will select ten Apple® iPod minisprize winners. Winners will be announced on June 18, 2004 on the Green Building Studio website at www.GreenBuildingStudio.com .
To participate in the survey click on the link below, and follow the simple instructions for the 10 minute web survey.
Take the survey at the following URL. http://vista-survey.com/survey/v1/survey.dsb?ID=1097094743
" {Greg Conyngham June 09, 2004 10.22}
http://tr.graphisoftus.com/
Jeffry Covarrubias
GS US Technical Support Team Leader
P-C2D 1.86GHz/2GB w/ 256MB GeForce 8600GTS; G4 OS 10.4.10 1GHz/1GB "[that other software] is a fancy set of electronic marker pens"
0 REPLIES 0
Learn and get certified!
