Full featured 3d in worksheets, like an independent story (with all the possibilities of the story, but without the strict order).
My feature suggestions:
- -possibility of placing the 3d-worksheet onto a storey, like an object, or like a hotlinked pln; left mousebutton: go to the hotlinked independent story (context menu item);
-even the possibilitiy of multistory worksheet;
-possibility to rotate or mirror, like an object (even with rotating in 3d window)
-worksheet save as pln, and open a pln as worksheet (could provide as flexibility as the components in sketchup - and even more: if not just local files could be hotlinked, but URI-s too)
-placing in sections/elevations window, too (even with 3d representation)
Additional infos:
- -if I knew a little of c++ I could almost do this add-on;
-with graphisoft's ac12 sdk it's not impossible to solve it;
-and this function could help to minimize the different functions of archicad. And as fewer the number of generic functions a software has, as better and easier the use of the software is.
A help with programming knowledge is welcomed (to do this add-on)!
Talmácsi, István, architect (AC user since 1997, ac4.5 - now: ac18)
