There won't be any nodes generated at the cut end of the beam which is why you can't snap to it.
But you should be able to snap to the other end of the beam if you can see it.
Or any other node that is level with the beaam - i.e. the top of a column or wall.
Constrain your slab to a vertical drag and you can use any point in space if it is at the right height.
