Wishes
A Stop button that works!!
That's right.
Everytime I try to stop a render or a 3D view that is taking too long to be generated, Archicad does not allow me to, no matter how many times you press that STOP "bitmap" (since it does not work)
It is so heavy and processor demanding that even my Fridge crashes and the lights start flicking when i try to stop a render in process..
6 REPLIES 6
Eduardo Rolon
hit command+period if you are on a Mac.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Ctrl+Break in Windows.
The button "Stop" or Hot Key worked well at the beginning of the process. But the more ArchiCAD enjoys the process, the less attention it draws to a request from the user stops.
Thanks a million for this TIP!
I have tried this TIP today on a complex 3D generation view and it did not work...
That's it. I've said that Archicad can seriously think and forget about the user.
Yep,
It pretty much does what it wants.
Learn and get certified!
