Wishes forum
Showing results forΒ
Search instead forΒ
Did you mean:Β
A few things to make GDL less frustrating
1. Auto save and recover. Nothing worse than your computer crashing and losing hours worth of work. Why isn't recover work in the GDL window?
2. When adding new parameters it would be nice if they appeared below the current highlighted one rather the end of a very long list.
3. A debugging spell check that checks spelling of your parameters comparing them to what you typed in the parameter list. Ditto on the GDL keywords.
4. A printed version of the GDL manual that actually made sense.
5. A magic key that would stop processing without having to press it 50 times before it responds.
6. The ability to copy parameter lines from one object to another.
7. To beable to see 3D hotspots on the 3D window.
8. An origin point on 2D like in 3D
I could go on but I think that will do for now. πŸ˜‰
17 REPLIES 17
Good points
James Murray
Does Command (or Control) +period work for you? It should stop most processes in AC. I have noticed in AC 8 that it's not as reliable as it used to be.
James Murray
Rill Architects β€’ macOS β€’ OnLand.info
1. Agree wholeheartedly, especially as Crashes often occur when you try to Save something if there is a fault in your loop.
2. How I have longed for this. Didnt matter so much before because the total number of parameters was in your control, but the new Subtype system means that your the undeletable FM parameters as so many that you own new ones are pages deep, and it takes a while to drag them up to join the other parameters.
3. We have been asking this for YEARS AND YEARS AND YEARS. Not so much for parameter spelling, but of key words, and auto uppercasing if its a key word, eg Block becomes BLOCK, etc. And auto-colours for parameters, commands, quotes etc.
4. The GDL Cookbook can be used as an alternative manual for most things, I do so because it helps me think of ideas for improving the next edition. I find my own book very helpful, especially in the Maths section. (It doesnt help in the dull things like listings of GVs, the GDLCB was never intended to be a full replacement for the manual).
5. Escape!!!???? Why not GS!?
6. These are perceptive comments, I have always felt that one should be able to build the whole parameter definition in the parameter script, and if the definition had the correct syntax, it would appear magically in the param table, just like Pop down valuelists do if their syntax is correct. And another thing - HIDEPARAMETER is great, but we also need SHOWPARAMETER to bring one back. otherwise tortuous logic is required to make a parameter show again.
7. aha!!! yes. sometimes you can place little spheres at those spots, until everything works. in fact you could have little spheres builtin into every HS routine, and have a toggle at the start of the script to hide and show them.
8. ditto, you can use a CIRCLE2 0,0,0.01 to simulate the cursor. I have occasionally built a subroutine that makes the whole of the cursor, in 2D and 3D including arrowheads, when you want the 3D view to show the cursor within archiCAD.
James B
And while we're at it....
9. Colour code scripts
10. A column to the left of every script numbering each line (with the ability to turn on and off).
I'm thinking the above would be similar in the way HTML editors work - like Dreamweaver.
James.
Technical Product Manager, Graphisoft
Aussie John
In text edit (onmac) you can type a letter and get it to show all the words in the library starting with those letters. (like when you type into your browser and it starts listing recent URLs)
How about if you start to type a global variable and you get a list of the variables. Same for 3d and 2d commands.
Cheers John
[/size]
I asked GDLTalk a question which led to an answer for this. Read all about it .
Maybe Oleg will want to post the official tip here. Very good. Worthy of GDL tip of the month, if we had one.
Oleg
Oh, no Alex, It is Roberto's tip + your important additions.
I am just tried to divide the tip to steps.
Your English is definitely better mine
This is tricky tip. May be you can to post it here in more clear words. My explanation will to puzzle not so experienced GDLers. I hope, Roberto Corona will not against.
Oleg.
owen
2003 post and i just voted essential. I get 1 vote in total on this poll? Were they reset or something? I hope this isn't a plot by GS to deny the democratic process .... well we were going to but no-one though it was important
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
Rob
My wish would be to have all undocumented and other (not included in current manual) features scattered all over different documents (like the library development kit etc) + all known bugs IN ONE GDL USER MANUAL.
::rk
owen
can't be done im afraid Rob .... it makes too much sense
cheers,
Owen Sharp
Laura Yanoviak
Yes, Yes! -- Essential
As of today's date, I see 5...
MacBook Pro 2.4 GHz Intel Core i9, 32 GB of RAM
AC25 US (3011) AC24 on Mac OS Catalina 10.15.7
NandoMogollon
I still don't understand why there is not a software that actually "writes" the GDL code.... Like Dreamweaver or Frontpage do with HTML...
In the mean time... i will keep trying to understand the Graphisoft manual... which was written to some one that actually knows how it works.
Nando Mogollon
www.nandomogollon.com
www.openBIMer.com
mail@nandomogollon.com
@openbimer
Now in Australia!
Revit 2017, ArchiCAD 20 AUS,
Dwight
But GDL code DOES write itself!
Save any assembly of elements as an Object and there you have it: a GDL written object. So quit whining.
What you are asking for is some magic sensor for parametric script creation.
And it won't happen because GDL is not retrogressive: you can write executable scripts that respond to variables [numbers of shelves in a book case for instance], but to ask an application to sense your meaning from an assembly of slabs is impossible.
If you want to learn GDL, obtain the GDL Cookbook.
http://www.nottingham.ac.uk/sbe/cookbook/
Dwight Atkinson
Rod Jurich
Missed this when first posted. Mine makes 13 votes.
That's 13 in almost 5 years!!
Is it any wonder GS see this as such a low priority.
And GDL being the foundations for AC.
Rod Jurich
AC4.55 - AC14 INT (4204) | ο£Ώ | OBJECTiVE |
Dwight
Low priority is correct.
Through the years, several GDL helpers have been presented but all of them went away.
Code is code and if you have the aptitude it is not so bad.
But the truth is that most users build their objects from primitive elements and do not require parametrics.
Dwight Atkinson
Well, sorry to bring up this worlds-longest-running-thread again!
If it was as easy as revits, maybe more would.
Just wondering Dwight (or anyone else), have you experienced or seen how revit constructs its library parts (families). I had never seen it before and I thought it was fascinating. (It's about 25mins long)
http://designreform.net/2008/03/12/revit-family-basics/
The example it gives is very simple, but it shows quite nicely how parameters are visually applied to an object.
Everything that it presents can be done in ArchiCAD at the moment, but doing it completely by code forces you have to think about it in a completely abstract way, which is difficult. This is one of the problems facing someone coding in GDL, how to visualise and quantify the correct geometry and the transformation manoeuvres to get what you want.
Something simple like actually being able to visually assign a parameter to a particular dimension on a piece of geometry could maybe help, not necessarily by using 'reference planes' as in revit, but actually to a preview of the geometry itself. How you then define the transformation visually from 0,0 is another problem to be solved later!
Rob
...and yet it is nothing new. I have seen this system in early 90'. that was developed by Israel/French team (and is still used) in AEC software ARC+.
::rk
