Wishes forum
AC19 Tab Layer Settings
gpowless
I am getting use to the new tab interface in Archicad 19.
Switching from different tabs requires extra steps to restore the layers and renovation to the last opened view.
In order for it to be useful, the tabs must be able to store the last layer combination and renovation status. Do you agree?
Intel i7-6700@3.4GHz 16g
GeForce GTX 745 4g
2-HP Pavilion 25xw
Windows 10
Archicad 25 USA Full
7 REPLIES 7
Eduardo Rolon
Double clicking on the tab does not work for you?
If not then you can right click on the tab and select restore.
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro M1 Max 64GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
gpowless
CODE 15! Code 15!
(The problem was 15" away from the monitor @-) )
Please delete this poll Thanks.
GeForce GTX 745 4g
2-HP Pavilion 25xw
Windows 10
Eduardo Rolon
Poll Deleted.
This was one of the items that was hotly discussed during the Beta.
OS X 10.XX latest
AC25 US/INT -> AC08
Nuge
I have just installed AC19 and was very excited about the Tabs, But after 5 minutes i am shattered to find out that you can only have 1 floor plan tab open, I had high hopes that this was going to be a great feature but once again VERY DISAPPOINTED with the new version, the 1 thing that was going to make a difference to me and wham NOT IMPLEMENTED!!! bugger
Nuge
AC25 i9 11900K / 128G ram / GTX 3090 / Enscape
This is because TABs do not change how Viewpoints work. They just offer a new way of arranging them in your application window.
A TAB is simply the given Window being pinned to the TAB bar instead of floating freely.
The Floor Plan Viewpoint and the 3D Viewpoint still have one Window each (all Stories in the same Window, both 3D Perspective and 3D Axonometry in the same Window). All other Viewpoint types, which are generated types, can have multiple Window instances (multiple Sections, Elevations, Details, Worksheets, 3D Documents, etc).
In summary, to be able to implement this the basic way of how ARCHICAD viewpoints and windows work would have to be changed.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Nuge
That's the point, i thought it was going to be a revision of how archicad works not just a simple alternate way of viewing the same information. If they wont implement this properly then at least give us a dockable layer window!!!
Nuge
Make a wish for multiple Floor Plan/3D Viewpoints.
For the dockable (and floating) Layer Settings Dialog there are already wishes:
http://archicad-talk.graphisoft.com/viewtopic.php?t=42516
http://archicad-talk.graphisoft.com/viewtopic.php?t=48974
