Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
AC23 Column / Beam End Cuts
DGSketcher
Legend
I have developed a timber I-beams complex profile to work with columns and beams for framing layouts. Unfortunately the new beam & column tools only allow for a single direction end cut within the settings which is fixed to rotate around the X-axis. In the images I have ringed where my problem lies. I have tried every variation I can think of to cut the top of the column at the required angle using my highest PBC values with roofs & shells etc., nothing seems to stop the inclined beam connection even after the column is trimmed. As can be seen I have even tried to connect the main beam & column axis. At present I can't see any other option other than duplicate complex profiles to rotate the axis. This seems straight forward but the duplication then messes up all my cut lists as the X & Y values are transposed.
I would really like GS to complete their programming on this issue and allow the cut plane to be rotated around the Z-axis. This would also then allow us to correctly cut columns to suit situations where the top incline is not perpendicular to a column axis such as a post at 45 degrees to a roof plane.
Lingwisyer
Guru
Add the cut functionality that the Steal Beam and Column objects have?
runxel
Legend
Also allow multiple end cuts!
This is so important to have.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
