2020-03-09 05:58 AM
2020-03-09 07:08 AM
2020-03-09 09:29 PM
James wrote:
From the 3D Document Settings (if it was created from the 3D Window), then go to the 3D Projection panel, and you can access the 3D Projection Settings from there. Then set to "Date and Time".
2020-03-10 07:54 AM
Matt wrote:
That lets you set the date and time correctly (our template has this all pre-created for each hour of the day)...but if you then go and change project north the 3D document will not change the shadow direction, it still generates shadows based off the direction project north was set to when the document was created.
2020-03-11 09:51 PM
James wrote:Great, fingers crossed a fix won't be too far away.
Thanks for the additional info. Yes I can recreate the problem. It works automatically for 3D Window views, but not for 3D Docs - need to reopen the 3D Doc Settings and 3D Projection Settings (then OK). I've entered this into our bug database, with ID GISS-903.
