Wishes forum
Ability to Schedule "Length of Reference Line" for Beams
Matt Balaam
We need the ability to schedule the length of the reference line for beams.
It is incredibly frustrating not being able to schedule the length of the reference line of a beam. It can be scheduled for walls, so why not beams? Length Left and Length Right are not adequate in a lot of situations.
Example: Eave/gutter profiles. The beam has eave sheets on one side of the reference line and fascia & gutter on the other yet industry standard is to schedule the length at the edge of the roof plane i.e. the reference line. Currently we can only schedule the inner edge of the eave (not useful) or the outer edge of the gutter (also not useful).
AC21 (8002 AUS FULL) | AC24 (4018 AUS FULL)| Windows 10 Pro | Intel Core i7-6700 @ 3.40GHz | 16GB RAM | NVidia Quadro K620
8 REPLIES 8
Have you tried using a railing instead of a beam and scheduling that instead? It allows your eave/gutter to be associated with your roof which is nice.
Related thread: https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=61547&hilit=railing+eave
Ling.
AC18-23 AUS 7000
Self-taught, bend it till it breaks.
Win10 | E5620 x 2 | 24GB | K2200
This is a good example.
Personally I model my eaves and gutter separately, but we should have consistency.
We can schedule the length of the wall ref line, we should be able to do the same for the beam.
If you want to play around with 'Properties' and 'Expressions in properties', then you could take the left and right length and apply a shift to calculate the length of the fascia position.
Then schedule that.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Matt Balaam
I'd never thought to try using a railing but after a bit of quick testing there is definitely potential! Thanks for the idea.
At the very least it can be scheduled correctly.
Matt Balaam
Modelling separately in our case just opens up another possibility for model inaccuracies when modifications are made, particularly given the only reason we would have to do it is the scheduling of the length. For all other purposes the single profile works well.
Then schedule that.
I have toyed with this idea, the hard part being working out the shift as all profiles are different widths and some have horizontal stretch planes to adjust the width of the eave sheet. Would also be hard to determine what type of join is at each end (no join, internal corner, external corner) within the available parameters of the expressions in properties as this will also impact the calculation.
Seems like a lot of complicated calculation for something that should be a standard schedule option.
How about using the "3D Length" parameter in the "General" group?
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
I tried this and it just uses the 'left' length - not the reference line.
Versions 6.5 to 25
Matt Balaam
It doesn't even seem to be using the Left Length. In my quick test I got Left Length = 113.85m, Right Length = 100.78m and 3D Length = 119.15m. All totally different and not sure how the 3D Length ended up being so much longer than any other length.
Interesting.
I just tested with a couple of beams mitring at a corner.
Ref lines 1000mm long with a 500mm offset to the beam.
Versions 6.5 to 25
