Instead of having to add text elements underneath a dimension line, can Graphisoft develop the dimension tool so that text can be included as part of the dimension object.
Ideally you would be able to select a dimension and click to the zone that it corresponds to with the result being the name of the zone appearing beneath the dimension line.
The facility to be able to manually enter the text name as custom text underneath the dimension line would also help those that do not use zones.
I believe this has been previously wished for and would contribute to more of a true BIM experience as well as increased productivity and reduce the chances of error.
