2017-08-14 10:55 AM
2017-08-17 04:24 AM
2020-02-19 07:55 AM
2020-02-19 10:26 AM
2020-02-22 10:55 AM
DGSketcher wrote:This! I use a dedicated Layer combination, a dedicated dimension layer and a dedicated elevation marker just for curtain walls. So each curtain wall has its own elevation (and section if you want). Then its just a matter of putting them in the corresponding layout and you can easily combine elevation, plan and section for each curtain wall along with notes for each one. The automatic dimensioning function works almost perfectly on curtain walls so its really easy to anotate. I still use the Curtain wall schedule option for picky contractors that want to know exactly how many meters of aluminium profiles are needed.
Rather than relying on the schedule, why not just have an elevation / section of the isolated curtain wall on a layout and then place the required schedule alongside it. I would expect the frames would be quite large so I doubt the contractor would be surprised if they were presented differently to all the "standard" doors & windows.
