Wishes forum
Add Ceiling Tool
Not sure what else to say here.
9 REPLIES 9
adamsb
What would this ceiling tool do? Add a dropped ceiling to a slab or roof? Add a "skin"?
AC21 64-bit
Mac OSX 10.12, 4.2 GHz Intel Core i7, 64 GB mem
Mac OSX 10.11, 3.4 GHz Intel Core i7, 32 GB mem
I think that a good ceiling tool with options for ceiling tiles and everything that goes with it, including the option to attach lamps objects to it, so if the ceiling is raised or lowered down the lamps will move with it.
I think this would help a lot
Paul King
Also should accommodate complex stretchy bulk heads, wrapping ceiling linings up and down vertical faces, or inclined faces of ceiling - so that they look right in section. With extensive stretchy ceiling framing/suspension system options that follow edits to ceiling form, rule based but with local positioning, length and cut angle overrides to any framing element
PAUL KING
https://www.prime.net.nz
ArchiCAD 8-25
Octane Render Plugin for ArchiCAD
Twinmotion 2021
Windoze 10
Intel Core i9 10900K
Nvidia Gforce RTX 3080
32 Gb DDR3
2x4K monitor extended desktop
Stuart Smith
My ideal ceiling tool would be similar to the roof tool, with the ability for lamp objects to cut and be associated with a ceiling the way skylights work with roofs and windows/doors work with walls.
This seems pretty simple, using concepts already part of Archicad.
AC user since 8.1
Current:
AC23 3003
Mac OS X 10.14.6
A lot of the functionality asked for here can be accommodated through use of existing tools you just need to think of the tools as not just a slab tool or roof tool etc but as a horizontal element with thickness or a sloping element with thickness with lights/grids etc as slab / roof accessories attached to the host element
Scott
I see there are a couple of 'ceiling grid' and 'ceiling editor' objects in the BIM Components Portal.
I have no idea what they are like though.
Versions 6.5 to 25
Stuart Smith
Scott
We use slabs and roofs as ceilings. I was really wishing for the ability to associate Lamp objects with them.
Could you elaborate on "with lights/grids etc as slab / roof accessories attached to the host element"?
Am I missing out on something?
AC user since 8.1
Current:
AC23 3003
Mac OS X 10.14.6
Stuart Smith
Great. I can start using that once I learn Japanese.
AC user since 8.1
Current:
AC23 3003
Mac OS X 10.14.6
