Wishes
Add Surface Area Calculation to Zones
ferarri
Surface area is a useful calculation for Architects and UK Planners as it demonstrates whether a building is compact or not. Compactness is essential in urban areas, but is also highlighted by UK planners in Rural & Settlement Edges to prevent expansion of the greenbelt.
The issue with Archicad is that the only way to get this figure is by using slab, separating it from all the useful features of the zone. This is unnecessarily cumbersome and requires a custom label to extract the information. Furthermore, you're unable to takeoff this information in a schedule without it producing a figure for the top or bottom surface, we need all of it!
If you need to change your slab, you need to update the figures on the layouts manually - not as refined as it should be!
Many thanks
I'm not sure I follow.
How do you want to measure surface area?
Are you talking about edge surface area or footprint area? Both can be scheduled from a Zone. See attached screenshot.
Or did I misunderstand your question?
Erik Bjornhage : SwedishChef, ETTELVA Arkitekter, Gothenburg, Sweden
Architect : Digital Development : Graphisoft Cert. BIM-Manager
ETTELVA Arkitekter : Eriks LinkedIn
DELL Precision 5570; i7-12700H; 64 GB; RTX A2000 [8GB] : AC12 - future
vfrontiers
While we're at it... how about this 20 year old request....  have zones DISPLAY the basic room dimensions...  Max X x Max Y would be fine... or include moveable hotspots ...
I have a very old GDL Object for room size, but would really like it to UPDATE along with the zone so making it part of the zones seems reasonable...
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
Jim Allen
Vectorworks allows you to adjust the size of its equivalent to zones by typing in the x and y dimensions box. A small difference but one which improves productivity significantly.
Archicad 27 UKI | OS X 12.7.1 Monterey
