2019-12-19 04:37 AM
2019-12-19 07:12 AM
2019-12-19 07:18 AM
2020-04-17 03:55 AM
2020-04-18 07:56 PM
2020-04-18 09:20 PM
2020-04-20 04:38 AM
holmarch wrote:
Crazy that ArchiCAD does not even know what an RCP is. They are basically plans but look up… nothing more or less. Or to put it another way... they are REFLECTED CEILING PLANS.
2020-04-20 04:52 PM
2020-04-20 06:02 PM
holmarch wrote:All you have said above is correct. The RCP plan layout stays the same e.g. you can overlay it on the floor plan and the drawing contains whatever you choose to display projected down from the ceiling level and above.
While I respect your opinion that an RCP is a plan cut above the ceiling looking down… I have never heard that definition. In our office (for the past 50 years), we follow the definition that an RCP is what you would see if you cut the room horizontally and had the ceiling reflected on the floor plan, like it was a giant mirror. You are going to see the soffits, roofs, beams, lights, etc. Handrails, cabinets and other items related to the floor would not show.
holmarch wrote:This is something different & a more complicated method. If you are looking directly at the ceiling image it isn't a reflection, hence the need for you to flip & mirror to get what you want.
If you use the 3d cutaway tool and cut from the bottom and look up, that is what you would see. See the attached that I generated this way. Of course, it needs to be flipped/mirrored, so it is the same orientation of the plan.
2020-04-21 02:43 AM
