Wishes forum
Add option to 'Merge Uniform Items' to Project Indexes too!
mmlahti
This is a small but continuous annoyance: When you have multipage schedules on layouts, and you add them to Layout Index (Drawing Catalogue), each subpage creates a new row with identical information into the index. To overcome this, we have to do tedious hacks (placeholder layouts and hiding the actual layouts via extra layout parameters). All this would be solved by adding the already in Schedules existing option to Merge uniform items to the Project Index UI, too.
mmlahti wrote:
Should the voting appear automatically, or how come this post doesn't have it available?
No it doesn't appear automatically.
You can edit your original post and add a poll.
There is a tab just below where you compose the post.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
mmlahti
Versions 6.5 to 25
