Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Add pen # and color area to info box.
If the pen #s were displayed in the info box one wouldn't have open the dialog each time to find the pen #.
I assume you don't have AC8.1, give your specs so we can be sure. Get it, and you get your wish.
Your other wish, if I understand it, is also addressed there with scroll-wheel zooming.
HTH,
James Murray
Archicad 25 • Rill Architects • macOS • OnLand.info
If you are using AC8 then you should make your info box larger. All the pens are there.
