I wish that it would be possible to adjust the height (especially the base) of the corner posts in the railings when you set the option for multiple posts with offset for the nodes.
See attached image.
If as in this case the corner goes from a slab to a stair (or incline) it would be desirable to set different heights to the base of each post.
As it is these corner posts can not be selected separately.
