MEP Branch Pipe behavior when START ROUTING is attempted from the end of a Wye or a T
CONDITION –A- Main line horizontal, branch out horizontal, Wye or T horizontal
No problems encountered. START ROUTING allowed snap to end of Wye and 90 degrees takeoff was possible as well as a takeoff on an angle using the guide lines
CONDITION –B- Main line horizontal, branch out rotated around ‘X’ axis. Wye or T horizontal
START ROUTING from Wye at a selected slope angle is not possible.
After the start, the only possible move is to introduce a small transition piece, which runs horizontal and then select the slope angle on the routing palette. This introduces an error in the elevation at the end of the pipe rise, when measured from the center line of the main branch since the pipe starts rising at a point away from the center line of the main
CONDITION –C- Main line horizontal. Wye or T rotated around ‘X’ to match desirable slope to takeoff
Under this condition, it is possible to START ROUTING at the end of the Wye but only after choosing the “bottom” position to start, then run for a short distance and only then we have the ability to select a slope in the routing palette. Also, if the takeoff slope turns to be less than 4 degrees, results are not reliable.
For accurate work with a takeoff branch at a slope from a Main Line, we need the ability to a) rotate the Wye to the desire slope, and b) start routing from the end of the Wye, with the “starting” branch recognizing and adopting the rotation angle of the Wye or c) start routing from the end of the Wye and be able to indicate in the routing palette the slope to follow.
This will result in a continuous slope from the center of the Main without the need to introduce any piece of pipe before start sloping away from the Main line.
CONCLUSION
From a horizontal or slopping Main line, in which a rotated Wye or T (rotated around the ‘X’ axis) has been placed, it will be highly desirable to START ROUTING from the end of the Wye or T, with the same rotation angle.
I spent many hours figuring out this work around and describing a desirable improvement and hope to see a patch with this implemented, very soon.
Yours truly,
Conrado Dominguez, San Mateo, CA
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
