2023-03-15 07:42 PM
Hi Archicad's elves,
Wouldn't it be more logical for Visible Elements option to be in the main menu of Trace & reference tool.
It is quite hidden now, don't you think?
It should not be so disturbing for you to change that little thing.
Pleeeease...
Thank you!
Regards.
Solved! Go to Solution.
2023-03-16 02:51 AM
The problem is, it is not just a command, it is a pop out palette.
And because it is not an independent palette (you can’t open it on its own), it can’t be opened from a menu item.
2023-03-16 02:51 AM
