jakubc7 wrote:
Not sure if this should be under 'wishlist forum' maybe?
Moved your post to the Libraries forum.
Does the "Floor Plan and Section" group of parameters not appear for this library part in the AUS library? In the US library, there's a cut line pen there. But, of course you have to over-ride the object's pen...since it is hidden as you say.
I'd prefer that we had the option to see all parameters for all lib parts as in the past. Too much magic can happen otherwise - notably with parameter transfer.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
