2016-08-11 03:54 PM
2016-08-12 01:09 PM
2016-09-27 04:41 AM
2016-09-27 05:28 PM
Da3dalus wrote:And add the others layer you need to add for others workarounds, I usually end up a project with a lot of extra layers just to get thing the way I need them.
Right now, we can only create ridiculous numbers of Layers to make Phases. !
2016-10-25 12:18 AM
2016-10-26 07:34 PM
Da3dalus wrote:Yeah, that's also a solution, really better than what we had before, but it is still to much of a workaround for a simple task, because you will need to do different rules for different objects, etc. it will be nice to have a simple option to hide an element.
You can't hide elements using a Graphic Override, but you can make them INVISIBLE. Pen 91 is always white in our pen sets, so I set all 2D elements to that pen. Then I change the surface to Air Space. *Poof* it's gone!
OK, this is a weak work-around, but it's better than what we've had!
2017-09-07 01:48 AM
