2021-08-20 01:26 AM
2021-08-20 04:03 AM
gdford wrote:What do you want to have happen after dropping the Excel file? A text-only display, as if it were a PDF? Of which sheet inside the workbook? UI would have to prompt you to select the sheet, and potentially the extents. Or, in addition, one that would update if the view was rebuilt? Or do you want it live-linked in a way that you can double-click it to edit?
What are the chances of being able to drop an excel document directly into archicad without first turning it into a pdf???
2021-08-21 02:27 PM
2021-08-30 09:00 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-09-19 01:45 PM
Cool Beans!!
