No actual need for the shift key.
This just speeds up the process and pre-selection highlights the label instantly along with any associated element.
Without the SHIFT there will be a delay that the length of which can be set in the Work Environment.
TIP: this works exactly the same for dimension nodes as well.
Hover your mouse over the node and the element it is associated to will highlight (and use SHIFT if you want instant highlighting).
