2005-10-29 04:19 AM
2005-10-31 06:51 AM
2005-10-31 03:36 PM
2005-10-31 08:58 PM
2006-05-25 09:02 AM
2006-05-25 09:26 AM
apologies for all the bleeping but i have just spent close to 5 hours cleaning up a mess of layers across multiple hotlinked files all because the simple ability to simply merge layers doesnt exist. It would have taken me half an hour if i could do that but no ... i have to go through and manually change the layer of everything on the layers i want to delete, then delete them. In 7 files. This is such a pain in the arseBut you can merge layers using the Attribute Manager.
2006-05-25 11:04 AM
2006-05-25 11:24 AM
2006-05-26 08:49 AM
Link wrote:The only way to actually merge layers (including their contents) is with strange and complicated uses of the merge command (actually I take that back, there may be a way to use the DWG translator and Smart Merge, but somehow just thinking about that gives me the willies).apologies for all the bleeping but i have just spent close to 5 hours cleaning up a mess of layers across multiple hotlinked files all because the simple ability to simply merge layers doesnt exist. It would have taken me half an hour if i could do that but no ... i have to go through and manually change the layer of everything on the layers i want to delete, then delete them. In 7 files. This is such a pain in the arseBut you can merge layers using the Attribute Manager.
Just open up a file in the right pane and either Append or Overwrite lthe layers. You can even merge layer combos, but it's a little more tricky.
Link.
2006-05-26 08:50 AM
