Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
AutoText Building Material Classification setting
gdford
We really need to autotext the assigned building materials classification setting for a single element or from a single skin of a composite or a complex profile.
If Building Materials are going to rule the data - then we need to be able to get our hands on all the building material data from anywhere in the model.... its bim afterall
Keep up the good work!!!
Lots of cool stuff in A25
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
4 REPLIES 4
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear Gary,
Thank you very much for sharing your idea about it!
If I understand correctly, the wish is about using autotext to call any Building Material's classification properties for any object/construction element from anywhere (floorplan/section/elevation/detail...), is that correct?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
gdford
yes - and to be clear this autotext feature really needs the capabilities to zero in on one skin out of many, from composites and complex profiles, and give us the ability to label "the ID" and/or, "the name" and/or, "the Description" and or, "the classification" of the building material that is associated with the single skin.
Also..... Building Materials should be able to have custom properties which should also be available for a single skin in the same way.
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear Gary,
Thank you very much for your clarification!
I have entered the wish as IDEA-1471 in our Wish List database. Hopefully, it will be implemented soon!
Once again, thank you for taking the time to contribute towards the development of Archicad!
Have a great day!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
that is correct
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
